quick help are the first weapons
  • Thread starter Thread starter Gas85
Gas85
Hello, everyone, I'll explain the problem quickly. I have to cut plasma a dash into a carpentry and I did the design using inkscape. I then saved as pdf and imported it in autocad because I don't know how to use it. doing so, however, I take all the measures and the carpentry cannot work. I can't set the measuring units in mm, or better do it but pdf is always imported in inches. can someone please give me the dxf from pdf? is a very simple bridge: 525 mm x 400 mm with a dozen round holes in the center, nothing complicated, but I am losing hours without results.. some pious soul?
if you have to make technical drawings learn to use autocad.
in the meantime search how to convert from inkscape to dxf, the tutorials are there.
Finally, who would give you a hand should also ask if you please give him the design or do you think you can attach it to your own initiative?
If I had the opportunity to convert from pdf to dxf I would not be here to ask for a hand. Fortunately, not everyone is as hot as you and someone is following me by private mail. greetings
I am talking about converting from inkscape (svg file) to autocad (filer dxf/dwg). there are tutorials on the network
if you can't read a simple message of a few lines I don't blame.
if someone is already giving her a hand and gives her news not to waste time on other users
chissa as never in the inkscape I just downloaded, portable version accessible to everyone, there is the rescue in dxf.
