engraving curve part
  • Thread starter Thread starter MaxBigno80
MaxBigno80
I have to hack a sketch on a spherical part so that the depth remains constant, how can I do?
if exported in iges format should be able to export even the sketches.
sure that to help people you should know how operations are done, what mistakes are found... it is not that writing does not work to understand what happens
created the sketch of the shape to be engraved, select coils, select the sketch, method wrapping surface spline, face winding the deep spherical part or,4 mm tells me that "unsuccessful winding the center of the sketch must be projected on the section"
Hello Massivonweizen
I tried to do the two sketches as you suggested to me, the first one does the second gives me the same mistake before you make a second sketch making a working mirror. ...
thanks max
Unfortunately, not even mirroring the faces I solve the problem, I think it is a problem of figure but I do not honestly understand why
dxf must be identical to that of 3d including origin.
opening the two dxf is clearly seen that the origin of part 1 is different from twin.
edit:
Like I didn't say, I took a bark. Sorry.
