(autosez 2) soil sections and profiles - automatic extraction
fantastic....!!! ! !
if I can .. ask. . ? !
it is not that you have in lisp that from the cloud of crucides/points that are to the various xyz coordinates selectdoli all or in part.. .
can I return its x e/o y e/o z value near the reference cross?
In particular, would I need to return only the z value, perhaps with the possibility of setting the round?
Like... 0 or 0.0 or 0.00... then (+ 0.00).
thanks 1000 and more.
good evening, when I try to launch on the program no window opens and this writing appears:
; error: an error occurred within the function
* error* setting of the rejected zwcad variable: "Osmode" nil
I tried to vary the value of the osmode variable, but it doesn't work anyway.
use zwcad+ 2014 pro.
thanks in advance
autosez works on autocad and gstarcad.
contacted by progesoft, I was provided an alpha version of progecad 2019 to carry out some tests, so autosez will be provided as add-on in that version, coming out in March.
for zwcad I received several requests from users, in order to get a copy (with trials I was unable to try) I contacted the Italian distributor and I was told that I would be recalled. . .
I don't have time.
Good morning, everyone, excuse a quick question. I only met autosez_2 now and it seemed like a great utility. I work in germany with a autocad in German autocad 2018 full. I tried to load the above as described but it doesn't work. I also read in the previous comments. Would someone know why I'm wrong with loading? Thank you.
Hi I read your request a year and a half ago, did you find a solution in the meantime? It was something I was looking for, too, and I didn't find it. Thank you very much
I discovered it only yesterday and it has already solved many problems. . Thanks again. Although I had read several posts about it is not yet clear to me one thing... is it possible to draw a profile with x scale different from the unit? ...I better explain...if I have two 30 m distance points...autosez draws such points always to 30m independent of the chosen scale (2, 200, 2000 etc) while for y the choice of the scale is reflected in the profile (as it is right that it is)...to understand us...100m from the reference share are plotted to 100, 50 or 200 depending on the scale indicated. in the x axis this does not happen. I'm sorry? . ...thank you and congratulations again for your work and for sharing it...I apologize if I may have asked a stupid question but I just can't change that scale....I have to plot very long pipeline tracks....thanks
if I don't remember badly, the scale affects not only for coordinates y, but also for the height of the texts displayed.
in the case of scales for the coordinate x of 200 or 2000 you should have the texts properly scaled and the management for the print of the profiles must be managed by the use of the windows in the paper space.
thank you for the answer....I don't know why but I was convinced that the plotting happened already in scale!!!....I feel a bit stupid....it was obvious that the cartiglio was drawn in proportion (y according to the x) and the scale is defined in the layout....it is only to "reset" the right scale for the readability of the texts....thanks again and I apologize for the banality of the question. congratulations again to gp for this application. I have in possession application of blasonate software house that I am not able to return a simple profile from polylinea....thanks again and good work to all!!! (We need it right now!! ! )
in fact the dwg is heavy, but in order to make tests you could also leave only some level curves
But...
from autosez help:
View attachment 44877Your section is a polilinea!!!
hi gp are novo of the forum... I was wondering. is it possible also with an additional application to autosez create the profile directly from the polylinea? How do you do it? :) thank you
What is that polyline?
attach an example dwg.
hi gp, I attach your file with addition a polylinea made by me in "red" you can get the same result using a polyline instead of a line (yellow)? I hope to be clear
I look forward to your new
hi gp, I tried to do as you say in the post:
"This lisp calculates the 2d profile that corresponds to the projection of a polylinea on level curves consisting of polylinee or spline.
After the appropriate tests (clearly not yet done, I hope there are no problems) is destined to be part of the autosez package and will automatically create the cartilage.
for the moment you can complete it with "data extraction\profile\poliline 2d on the floor", setting the right "first step" e idonea "reference share".
the design direction of the profile is influenced by the position of the selection point, the distance between the vertices takes into account the possible curvature of the tracked polyline.
@bleezeIf you have problems on your model, try to move it near the origin of the bird, exaggerated distances as in your case can give problems, even with normal autocad functions.
also take a look at the track, which in some curves passes where they were interrupted for the positioning of the texts of the quotas.
ocio that you also have 3dpoly with vertices not at the same altitude, these will be clearly discarded by the procedure.
AnnexBut maybe I did wrong something... going on "data extraction\profile\poliline 2d on the floor" gives me something like this is correct? Can I create a profile away from the original design?
I attach you test files
