info workstation cpu 1x i7 vs 2x xeon
  • Thread starter Thread starter strudeldemele
... in the pc you linked I would change the power supply with a decent one and the heat sink for the cpu with one air or liquid of good quality.
It's my home computer :lol: taken two and a half years ago... to which I added another sdd...
only cows: the fan feels and the green leds are unguardable:poop:
so as pc-mulet for an office could almost stay. . .
thanks to the opinion (y)
the ryzen 1700 is an octacore with 16 threads and is a multipurpose cpu only goes overclocking a pinch.... What's the fan? ....you can always replace it with a good quality such as noctua or similar brands. a pc like yours is a purchase that as you say... minimum maximum cost yield.... with a decent power supply and a proper cooling cpu and if the house allows a good internal aeration hardly will give boredom.... grinding whole days of activity.... I love the logic of assistance and time dead for companies and big studies but for all others as you see with an honest expense you can pull out decent ws.
... the fan that makes noise what it is? .... you can always replace it with a good quality for example noctua.. .
There is one on the processor, one on the video card, and two on the house (one in front and one behind)...I amho are these two last...who wish I could replace as you said with two quality...they are not exaggeratedly noisy cmq... (y)
with an expense between 15 and 50€ you can install a fan controller for front and rear fans....you turn it to the minimum allowed regime and the noise will be very attenuated.
1- I need 5 workstations but we crave a little in the dark (plus my owner than me) in the sense that, as always wants a great product without spending; therefore we are considering whether to rent or buy a assembled by the technician following us;
2- ale47p I at home have a regenerated ws hp z800 (complete 4 years ago and had already 2) with double xeon (I don't remember the type) 64gb ram and nvidia p2000 I installed win10 and is still going better than the ws of the bought not even 1 year ago (some ignition processes are slower but in fact of stability and calculations relative to the 3d software there is no
--3--- for the nuive pcs I think I will point on an i7-9700k - nvidia p4000 - 32gb ram expandable probably by making me assemble ad hoc (the preassembled give me the idea of wanting to make impressions with cpu and gpu and ram but then the contour (houses, motherboard, the same brands of ram and all the contour) leaves a little to wish
Allow me an observation if the price between the p4000 and the new rtx 4000 is similar or slightly more..... from the preference to the latter that has a performance boost not indifferent.https://www.storagereview.com/nvidia_quadro_rtx_5000_reviewin the review you find a comparison between various cards
hello to everyone, we are going to the 2019 version of s.w. with also composer. As long as we don't do fem analysis.
modeling - asmbalti with about 200/300 pcs - manualistica con composer - render with use of photoview (materials already set by time) we opted for this configuration:
workstation wk-05/mod intel i9 9900k 3.6ghz ddr4 32gb m.2 500gb p4000-8
case: corsair carbide series 200r middle tower atx
alimentatore: corsair tx750m 750w 80plus gold modulare
cpu: intel 1151v2 core i9 coffee lake 9900k 3.6ghz 16mb 95w
dissipatore: corsair a liquido hydro series h80i
scheda madre: asus 1151v2 prime z390-a atx ddr4
memoria: corsair ddr4 32gb (2x16gb) 3000mhz cl16
m.2 ssd: crucial ssd m.2 p1 3d nand nvme 500gb r1900 w950 mb/s r90k w220k iops pcie 3.0 x4
hdd: 1 tb wd10ezex
scheda video: pny nvidia picture p4000 8gb gddr5 (required the price difference between p4000 and rtx4000. )audio card: integrated 7.1 hd audio
optical reader: dvd sata burner
Yes. : windows 10 professional 64bit lic. adesivanetwork: realtek controller gblan
guarantee: 2 years
workstations assembled by a store of our confidence (from about 6 years) and never had problems.
When he comes, I'll take a few tests to see how he goes...
hdd: 1 tb wd10ezex
guarantee: 2 years
How much does everything come? ?
total 2070€ VAT included with p4000 framework
the price differences between the p4000 and rtx is about 200€
I started from this configuration of a wk that propose:
workstation wk-05: 1740€
houses: corsair carbide series 200r middle tower atx
power supply: corsair tx650m 650w 80plus gold
modular
16mb 95w
heatsink: hydro series h80i
motherboard: asus 1151v2 prime z390-a atx ddr4
memory: corsair ddr4 32gb (2x16gb) 3000mhz cl16
r1900 w950 mb/s r90k w220k ips pcie 3.0 x4
hdd: 2tb 7200rpm 64mb sata3
video card: pny nvidia picture p2000 4xmdp 5gb gddr5
optical reader: dvd sata burners.o.: windows 10 pro in versione trialnetwork: realtek controller gblan
guarantee: 2 years
not bad altogether.... for a matter of performance as well and reliability I would have chosen a samsung 970 evo or pro, a seasonic as power supply and the rtx 4000..... but I understand that the price still rises a lot of hundred.
hello to all
It would seem that this is a good configuration for my intent.
  • intel core processor i7 9700k 3.6ghz eight cores up to 5.0ghz in turbo core
  • 32gb ddr4 2666mhz
  • sd m.2 500gb smsu 970 evo
  • Hard disk sata3 1000gb?
  • masterizzatore dvd
  • mainboard z370 intel
  • video pny nvidia picture p4000 8gb
  • scheda sound 7.1 onboard ?????
  • lan 10/100/1000 onboard
  • modulo wifi 300n ?????
  • 750w certified power supply 80+ gold
  • houses midi atx sound absorbent
beyond I should go up a lot of price
hello to all
  • 32gb ddr4 2666mhz
price? ?
cpu is good a pinch of oc and goes over 5ghz on all cores...which heatsink mount you? the picture rtx 4000 how much it comes extra.....net is located at great prices.
it is unfortunately I have to lean on external technicians..... oc to 5 ghz are down in agreement for fans and adhoc heatsinks (I planned them....here I do not fuck)
I don't know, do you say it gives me much advantage??? from how I use sw it seems that the video card does not work great, even I thought to put a p2000 (only it seemed to me that it did not hit us anything with the rest
above I had posted a link for a comparison between vga.... who said that the vga doesn't work..... works and as if you work...... depends on what you do..... rtx 4000 is a nice step forward.... in the perspective of a couple of generations of past vga....I would like to take one to replace my firepro w5000.
for the news https://gpu.userbenchmark.com/compa...vs-amd-firepro-m6100-firegl-v/m716215vsm10287The m6100 is aligned to my w5000.
hi taurus77 , I say that it does not work x the work that I do (only modeling) xè I tried for about 20 days to keep under control all the values of ram cpu gpu etc and gpu (p2000) that I use it to maximum 10%; Keep in mind that I'm not very practical with pc but I know that's the value that tells me how much I'm exploiting gpu, if it's not so please explain to me at best or give me references to understand how to reason about its use
Thank you very much
Thank you very much
Current
Well if your modeling is limited to a few pieces and you don't make assemblies or push display with complex wireframes... .then maybe the p2000 is for you...the professional vga cover various scenarios of utlizzo render, wireframe, shady scenes and other situations that can be presented according to the software of use....the price difference between a p2000 and a rtx 4000 is about 400€ not little but also if it has a way to squeeze it. What kind of work do you do and how complex are they?
are conveyor belts, handling, manipulation, but construction is always very similar, a normal assembly has 50 pcs up to 200, among other things are geometric constructions without complex surfaces (work also with thermoplastic molds and is all another thing, a 20pz assy can be heavier than the worst conveyor belt)
Moreover (for now) it is only modeling, boards, dwg for laser, for this reason I thought to digest the p4000 to the head but also the 2000 I think can go well
the unknown is for the future, I'm trying to automate the construction of a product in which you need to insert some parameters and others are calculable, I made an excell for the calculation and I'm trying to connect it to the parts to be built (perhaps this occupies space)
I understand... according to me I think that the p2000 goes well... as I have repeatedly stated in other discussions I tend always to oversize the pcs I assemble not to poke in various grains.... if it is not a expense made in affanno take the rtx 4000 for a greater longevity if instead the mountain spending is an invaluable limit p2000 should comply with your requirements....until today with which vga you have worked with ?
I was hired to teach 3d with solidworks. I'm actually doing a half revolution, so now the only 3d pc has a p2000, but our technician would like to use gtx 1070.... according to him the picture doesn't need anything.
