Please. sinthanks for the answer but it does not work.... .
hello but you want to handle it as a single piece or two separate pieces? In the second case I agree with massivon.in the first case you have to build it differently to have development.hi, I modeled / enlarged a half of a symmetric support in sheet metal so I started an axieme I inserted two instances and finished modeling.
Now I need the two-part flatteners.
I know, it's simple, I'm not leaving.... .
solidworks 2015
Thank you, no matter what.
Hi.View attachment 53729
it is not possible to help him.but it doesn't work
It is not neccesary to import the sketches, just propagate the functions to the parts.With regard to machining, excavating, holes, etc., you can import sketches from the set into your single sheet so that we remain further processing in the particular flattened
is likely but we do not knowIt doesn't work because he's trying to make the development from the axieme. . .
I tried i... has two extra details added work in the axieme.. .It is not neccesary to import the sketches, just propagate the functions to the parts.
This attachment contains a detail of yours that I have saved in development in scale. a dxf and a tav sw v18hi, I modeled / enlarged a half of a symmetric support in sheet metal so I started an axieme I inserted two instances and finished modeling.
solidworks 2015
as I wrote I opened the file and saw how it is done and I also asserted that the side files flatten without problems and I linked a page, and there are many others in the forum, in which it is explained asI tried i... has two extra details added work in the axieme.. .
You don't understand what you mean by this phraseI never use import of sketches or other processing on either side even if the 3d allows it.. question of organization of the company and working methods imposed. I have collaborated with the coetry group and reaffirm the concept. They are very tax and share. . .
*I proposed as to follow the desired shape you can import the sketch but then build with the quotas the definitive sketch. . .as I wrote I opened the file and saw how it is done and I also asserted that the side files flatten without problems and I linked a page, and there are many others in the forum, in which it is explained as
you never use sketch imports, but you propose it to others. to someone can serve to do work together of two different parts for various reasons., maybe he must bend separately the details and then once welded to work them... What do we know? or his method of work is optimal with the workings together and then he forgot, or he did not know he could do it, propagate them to the parts
What does the cohesian group have to do with it?
small note, if you attach a drawing file without part does not serve anything and also a dxf without bend lines or bending data does not serve anything
first of all thanks to all for the patient kindness granted.we have read in three users that you can develop.
I ask gracefully to explain what does not work, what procedures it performs and other because with the phrase
in the link I put to post #2 is the solution https://www.cad3d.it/forum1/threads/ripetizione-piatta-su-tavola.55378/#post-431303. of course if there is no development configuration as in this case just follow the last step and that is to say, open the drawing, insert the view of the sheet and put the tick on flat view
