execution mechanical processing by the unknown name.
  • Thread starter Thread starter gigiluigi73
gigiluigi73
Good morning.
I do not know if the problem has already been dealt with, I do not know exactly the name of the processing and therefore it is difficult to perform a search.
I should perform the red circled workmanship in photo_1, I tried to run it with the command "connects" and it comes as in drawing_1 and drawing_2, but it is too connected on the edge (90°).
Is there anyone who can give me a tip?
thanks in advance
Good morning.
thanks in advance
would seem like a bevel with fitting/compensated output... .
could be a reconnected exit as told by new rider or even without fitting and the radius would be that of the tool
In my opinion, it is the various past of the tool, in the end that could be a "agreement" made by the tool radius in more past.
does it have a very precise function that serves like this or is it just an exhaust?
no, it does not have a specific function, except to allow the bar to rotate and not to go to bump another near through the unloading. . .
In fact the piece is already existing, worked on the lathe and the cutters, and, taking inspiration from your answers, I tried to extrude by cutting in "revolution" mode the material, fixing axis at a certain distance, and the result to which I have arrived is definitely better (see design 3 and 4).
just create a sketch connected on an angled plane passing through the edge (although it is not necessary) and get this:
