drain on edge
  • Thread starter Thread starter LucaP79
LucaP79
Good morning.
I find myself having to make an edge on the upper edges of a box, folded inside. see image attached
I tried to use the edge command, but the 2 created edges intersect on the inner side and in no way I managed to create the discharge, (also with the custom drain).
Meanwhile I had to use a 179° edge flange even if it does not match reality.
in the manual that I attach the photo it is written to set the " corner cut game ", parameter that I do not find anywhere.
Does anyone have any suggestions?? I don't think it's a version problem (I use 2015) as the manual page is the same as the 2020 version.
the game on the edge you get when you do the function on the same face of the sheet metal
Thank you for the answer, so with the command I deduce that I can't fix. . Do I have to leave a flange of the edge at 179°?? or is there any more "intelligent" way? ? !
Good morning.
traduci da http://help.solidworks.com/2018/english/solidworks/sldworks/hidd_sm_hem.htm?verredirect=1mitergap.webp
in italianohttp://help.solidworks.com/2018/italian/solidworks/sldworks/hidd_sm_hem.htm?verredirect=1
Meanwhile I can tell you that making holes with sketch repetition is a suicide in terms of performance.
the repetition of the function is much leaner; Moreover it has the advantage that in a table you can temporarily suspend the repetitions to complete the design and reactivate them only at the end.
I can tell you that, on my pc and with 2019, your version takes 3 seconds of regeneration of the part while with the repetition of the function takes 2 seconds; seems little, but in other contexts (axioms and tables) this difference makes you feel
