MassiVonWeizen
insert global variables into the main axieme, double click on the glass quotas, write = and call the variable
Hello everyone
then, I deceased all the external references that were within the parts and destroyed all the equations that I had previously inserted at lower levels of the assieme father, so, if I did not forget a few pieces, the parts are parameterized only by the global variables of the main axieme.
Okay.
However the design (c009-20 order glass.slddrw) continues to not want to properly recep the different configurations.
The global variables I have inserted work on "all configurations" as the glass with all its components have the only default configuration.
if you select the view you can change the configuration
I send you all the package because I no longer know what fish to take.
Thank you very much
yes caspita is true, I had not read it carefully, I had not understood that in the end it went to insert configurations on all the elements (which were affected by the varying configurations of the assieme father) of all levels while not having in fact any specific function or dimensional values to match each configuration. . .In the end it is nothing transcendental, I followed what was explained, or rather how I "translated" it, in the link of the post #17 and that is to use configurations even at the lower levels. And then I got a little bit to play with the graphics... so' boys![]()
No problem. So I learned something new. a lot of what I know is fruit, besides it has a morbid curiosity, also to study the problems that are placedThanks massive, you saved me again.. .
