add fine step threads not selectable
  • Thread starter Thread starter tecnicoSIP
tecnicoSIP
I would like to know how to add in the drop-down file (selectable) missing threads.
then to make her appear the note in the draft you say and where should I put it in the callout?
if you have to add threads you have to change the toolbox. in the forum has already been treated as changing the toolbox to insert threads
I added the size but in the hole creation it does not appear equally
you entered the values in the wrong tab.
the category you have selected, straight holes, corresponds to the 3rd icon at the top; you can check the 4 matches under categories.
instead you have to insert the values in hole from center where you will find under categories short preforum, preforo standard e threaded hole bsppI have no idea why it is called a center hole. .
Yes, that's how it works. Thank you!
