I added the size but in the hole creation it does not appear equallyif you have to add threads you have to change the toolbox. in the forum has already been treated as changing the toolbox to insert threads
I also restarted sw
Yes, that's how it works. Thank you!you entered the values in the wrong tab.
the category you have selected, straight holes, corresponds to the 3rd icon at the top; you can check the 4 matches under categories.
instead you have to insert the values in hole from center where you will find under categories short preforum, preforo standard e threaded hole bsppI have no idea why it is called a center hole. .
