gianmarco_h501
Good morning, everyone.
I have to draw a lifting hook and I found a problem that I can't fix.
The procedure I adopted was as follows:
- basic sketch design (top)
- design of the various sections
- extrusion with loft with guidelines
all right here, the problem is when I go to table the hook. I practically can't quote anything, it's like he had joined the guidelines I gave him on the loft creating a spline, a unique line. For example when I want to go to quota the 30mm connection radius, select all the guideline and not only the radius.
the only way that comes to mind to solve is to quote the basic sketch, but in that case I can not remove all the construction lines that I created in the design phase.
I also don't know how I can combine the tip's "cupola" with the rest of the body so as not to show that annoying edge.
I attach some photos and the file to make you understand better.
