Roberto377
as I am trying to perform I am blessed exercise that includes sides from 3,50 x4,00 and as diagonals 5,32 possible that you can not perform correctly by making roundings with a program like autocad, then what you want me to tell you since you do vittimism ,sbagli etc etc, if you want to close the postexcept for the case that mathematics has not become an opinion, if the text of the exercise, which is not known what it is, reports as diagonal 5.32 instead of 5.31507 (attention that is this 7 final that rounds to the upper digit instead of the lower one) means that it has rounded the figure to 2 decimals. As a result the size results from a construction with this measure cannot be detected with 3 decimals because they will never be corrected. Is it clear to you the concept of the thousandths at stake? Have you seen the image that I attached in the previous post or read only what is convenient to you?
we are at the #18 post is you have not attached the file to see the construction and analyze its possible problems, the video does not explain anything about how you built the rectangle and you see only a line and a flicker, you call into question an exercise that many have read without citing it or reporting it... seems to read the arguments of the landplants and similar.
to me it makes sadness to see users who pout and make free vittimism because it has been pointed out that they are wrong, users who have been widely helped, even by the undersigned, and have not complained until you have settled them
