welded length of multibody part saved from together
tanticapelli
Hello everyone
as (in order to group the identical bodies) I have the habit of saving a set of a project containing multibody parts (at different levels of depth) in another part and while activating the welding function I get a separate cut, I wondered how it could be done quickly also to light the length of these dorps so that in cutting distinct table can be read as it normally happens.
I hope I've explained
so many hairs
Since when you save a set as part all the properties of the cutter are lost because each element becomes an imported body without history I think the only way is to make the selection boxes.
this pane will be optimized for minor footprint
Excuse me but what are the selection boxes??? ? Maybe it's stupid question but ....I don't know about it or maybe you and I never called them so! in the guide doesn't explain really well thank you hello
right pulsabte on the cutting table in part environment, at the bottom of the context menu you will find this entry that creates a dense 3d pane around each individual body and automatically compile the properties of the distinct with the measures of that pane.
if you expand one of the separate folders you will find a 3d sketch called contour box
mythical?
