create displayable and editable share directly from model tree
  • Thread starter Thread starter Viollo
Viollo
Good afternoon to all,
I hope I have entered a title and I can explain well:
from my studies, I remember, with catia there was the possibility (I don't remember how but) to be able to view a certain share of a feature directly on the model tree, so that you can act quickly on that dimension and constantly have it under your eye.
I try to explain myself: let's say that I have a representative model of a spring. as normal display, I have a spring height equal to rest spring. now, I must be able to pass from the height of the rest spring to the height of the compressed spring, and vice versa, quickly and easily consultable.. Is there a possibility to make the height of the spring appear directly on the tree so as to change it with a click and control it every time I open the design?
thanks in advance for any answers!
add a column on the tree, typo parameter model,
and write under the name of the size, e.g. d141
hinges
Hello, thank you for the answer.
How do I make a quota as a parameter? I set the parameters like weight, description, code, etc etc. but a quota in the parameters I never put it. .
Thank you again!
I tried to do it but there are 2 problems:
the first is that I cannot rename the column, it remains only with the number of quota.
the second is that if I close and reopen the model, the tree is not saved. I could save it, but after that I don't find the column on all the other models trees? I'm interested in only having it on this "molla." . .
If you want to rename the column, you need to rename the size parameter. .
if you want to see this quota only on this model,
make a note with this quote:
#annotation
♪ Attached_note[Lunghezza molla &d141]cation
Arni
ok the solution of the note seems acceptable to me! Thank you again for your help!
The last thing if I can... by curiosity, how do you rename the parameter of the size?
explained better because quota and parameter, are distinct elements in pro-e / creo and have different possibilities in fact of name.
ciao @320i s I don't know if you read the discussion before... In practice I look for a way to bring out a quota to be changed directly into the tree, so as not to enter the modality etc.@arni1 He initially suggested me to create a column in the tree with the quota, and it worked, doing exactly in my case, but there were two problems: you could not rename the column (that remained e.g. "d153") and in addition I had to save the tree with the additional column as standard, and I would find it in all models. . .
Anyway, asking him how to rename the column, he suggested "rename the parameter of the size"... now I honestly don't know what it means, I asked for lumi on purpose.
for the "negative" reasons that you described above, I would personally use a parameter in part to associate the quota (at that point you do not need to rename it), the parameter then has the advantage of being recalled in the tree, for all parts/axis that need this change "fast" from the tree.
of course the saving of the tree is obligatory, unless you save the tree.cfg at boot directory level and points the config.pro them.
So, forgive me if I'm wrong, I could only create the parameter in the "parts" that interest me, call it back to the tree and save the tree. But then the column in the tree would only appear in the parts where the parameter is present, correct?
the column you have to recall it in the assemblies where you are interested, the tree.cfg is a setting that if you change the one that loads the config.pro, you will have on all the assemblies, that column, if you want it on certain assemblies, you have to call it back at a time, or play it with the config.pro in the folder where you are working and create the program start icon starting from them.
All right, thank you very much!
the last question, how do I create a parameter and associate the quota to it?
Reports below must be set "pre-regeneration"
Enter the name of the quota == parameter name
es:
d153= length
if you reverse, however, eye that the parameter will depend on the quota.
Thank you very kind! in fact I had tried the last days but I did the opposite!
Thank you again!
Good day
