pack and go
  • Thread starter Thread starter genesis1975
I feel like reading a bit of a nuisance in your last answers, I hope I'm wrong
I don't know how to use window explorer, so if you want to tell me first why I can/can't delete the referenced assemblies from the copy folder. .
read post #72.
a file opened by a program can not be deleted. In fact, you will get a warning similar to that of the image.
a file not in use in any program will be deleted normally and will end in the trash that you have on your desktop
Yeah, you're wrong. But I know you'd like to explain to me windows explorer, but it's enough if you tell me if I've answered your questions well, and with four words, you explain why I can cancel them.
ah thank you... the one where I give myself some tonto myself...;) and what I have to do... more so...
Then we didn't get to post #91... in post #44, in the image, there's all the copy folder... one I want to delete is selected,
the other is the other assembly file referenced, the pos 160 a15 gs.mon that has nothing to do with the main that interests me, the pos162h18.mon
because we talked about the im-00301 that is in h21, but not the pos162h21gs, inside which it is contained, and pointing to the assembly folder. . .
not for that, but because you understand the context you refer to.
the other #67 and #68 do not understand if they are statements or answers and if they are answer to what question.
@65 even makes you think that you are talking about icancellars from within the axieme and that is to open solidworks and delete them as in post #46, which is not what you are discussing.
your talk about subaxis and first-level files just messed up the problem because if you need to delete a file from explore resources (like your post #44 image where the file is placed it does not matter)
Then we didn't get to post #91. . .
We'll get there. Anyway I was wrong to write with my phone and I meant the #81
the image you asked is the post #44
then follow the points listed in post #72.
if the file is open in solidworks will not make you delete it and will give you notice message otherwise delete it
Sorry but now I'm home and I don't have windows explorer....if you want to answer me for now answer the post #85 and #86
Well, it's not a question, but it's the ones I didn't want from the beginning, that I didn't ask the pack and go... those that I was worried about canceling... if you tell me to cancel them, answer my question... and I add that I can erase them because they point to the mounting folder, right?
Maybe the question of windows explorer if you have time we'll see it tomorrow... even because I don't have solidworks now.
and I add that I can delete them because they point to the assembly folder, right?
you can't delete them because both are referred to the min-00158_mon file. you can delete them only if you want to cancel even min-00158_mon and pos162h18_mon
solidworks and windows explorer have nothing to do with each other.
and how to say that in the garage you have a car; I tell you how it's done and what a garage needs, but that there's a car or a bike or it's empty doesn't need to know what a garage is or how to use it.
do you need the min-00158_mon file?
inside the axieme the file pos162h18_mon you need?
the copy set? all that's inside the assembly are the parts of pos162 h18, it's the main one I want...I didn't want the other two that added me, the 15 and the h21....if in the copy folder I open the pos162h21gs_mon and I find references it doesn't just fit me?
the copy set?
Of course it is the core of all the discussion.
All that's inside the assembly is the pos162 h18 parts, it's the main one I want.
then why do you put the screens of the axieme pos162h21gs_mon?
I bring you back how to solve most of the problem I had written even 60 posts ago
final solution:
make a zipped pack&go of the axieme h18 you're editing.
delete all the contents of the folder
decomprimi the zip file
at least if I gate h21 and a15 at most deletes the copy of the spring and the copy of the h18. Doesn't it erase me?
