PIETRO2002
But why do you want to use the sintered pieces? Do you have such high volumes to cushion the cost for mold construction?
so it would seem.. .But why do you want to use the sintered pieces? Do you have such high volumes to cushion the cost for mold construction?
I think you want to land with this product and it seems already in an advanced stage... But there are technical problems as well as problems of manufacturing times.But why do you want to use the sintered pieces? Do you have such high volumes to cushion the cost for mold construction?
you have to decide, but it is not worth stopping, try traditional gears, do open/close tests, make changes and within a few months to start with the large scale series?You said well, my reality... I thank you and I admire you for the interest you are showing me.
volumes could be great with the right product. even if I realized "only" 1000, for some details, see the crown or the planets, would already be 10'000 units from 0.2-1 euro per piece. every mold comes to me on average 2000€.
I have white hair, you mechanicalmg, you are certainly younger than me! but we are on the same wavelength! good connoisseur few words. . .you have to decide, but it is not worth stopping, try traditional gears, do open/close tests, make changes and within a few months to start with the large scale series?
the risk of business is also able to plan and evaluate.
pietro, in fact at first enrico had written me in private but then he convinced himself to share his project.Surely now we have put him in crisis with our observations, but we are told it is better to become red before you pale after! face is lost not so much in looking for solutions, but doing wrong things and throwing money in the trash. .
I would buy gear from business. . .That's why I'm here.
before proceeding with the molds I make samples certainly, but I have to get them out of the full. or to get closer with the new sintering techniques via 3d printing.
even if I assume they will not be comparable.
try to think traditional.That's why I'm here.
What I can tell you, not being in your industry, is that you have to be sure whether there is a unified standard pair that you have to achieve for every type of valve.Maybe the problem here is just the power out there that I set myself up.
before reviewing the project we used a small parallel axle motor of the "nuovakiwi" from 8nm and opened 1"1/2 ball without particular problems.
then with another simple 8-56 stadium we also opened 5" butterfly.
with the going of time, then a few little problems came up.
Am I making too many mental pippes about the forces to reach?
widening the band in theory increases the strength of the tooth because it is distributed on a larger area, but this means having particular worked very well both as toothing and as alignments of the trees, otherwise contacts between the teeth are distributed only locally, thus eliminating the benefits of having increased the width of the band.What does it mean to enlarge by 10mm the circumference of the crown? Would it change something or would it remain more or less unchanged the result?
Would you reduce the band width a little?
to increase resistance:What does it mean to enlarge by 10mm the circumference of the crown? Would it change something or would it remain more or less unchanged the result?
accepting also to descend respective to 40nm and 160nm...
but here we talk about "sintered"....but what material?to increase resistance:
increase the module
increase the width of the tooth
use of high quality steels
do the appropriate surface heat treatments to increase hardness
rectifies gears so you have a "perfect" contact
optimally mobrifique with the right products
I think we're not going far.What does it mean to enlarge by 10mm the circumference of the crown? Would it change something or would it remain more or less unchanged the result?
the type of sintered material is indicated in post number one and two. in the post two there are mechanical characteristics.but here we talk about "sintered"....but what material?
I would, of course, for a product like this to exclude grinding operations, but also the disembarkation seems too
for lubrication, if I understood the product, you must rely on the load of initial fat and good night, no one will ever go for fields to fatten this business
In fact, in my answer I was on the theory.but here we talk about "sintered"....but what material?
