Domanda?
  • Thread starter Thread starter Stilho
I have an idea but I am not entirely convinced that this is the right option
If you hold it in your head there is no comparison, but only a unilateral exchange from us to you.
even if you are not convinced of your idea to expose it; If it is wrong you will understand why, if it is right you will understand that you have made the correct reasoning.
A presentation is welcome!
automatic quotas do not come so at home. are filmed by what the user created in 3d so not only in the sketcher.
Well, he doesn't always model as then he'll be in the drawing.
I, for example, that I never amount the quotas of model 3d because I quote ex novo the drawing, I do not miss to quote a certain way, but I do it with the objective of comfort and the context and if this means to put the 33 instead of the depth of the lamatura quoto the 33.
I do an industrial technical high school, in which I demand the ability to make two products, to say everything I am not a monster in the design but I like to design the design I think it is my future, and for this I want to try to learn as much as possible from you that you are already more experienced within
Maybe I expressed myself badly and maybe you had a bad opinion of me....I apologize I just want to try to learn and learn as much as possible
However this is my sketch that I have done now very quickly, it is designed very badly but it is an idea of what I do in the head
and why does the topic prove to be planting?
No! the topic is the technical drawing. with the planning not to anything to do.
Maybe I felt bad and maybe you had a bad opinion of me
You didn't say bad, you wrote a crap. I answer according to what I read, then over time also according to the person, and if I read planter I deduce that it is a worker who handles drawings and I stand perplexity.
By the way, the internet is not a software but a breowser and has no relevance to the topic of the forum that is technology and transversally fields that accompany it (design, legislation. . . )
Yes, this is more or less the sectional view I posted to you. Do you think it's okay?
thank you very much of the clarification, I only wrote plants because the matter from me is called plants, about software I apologize also here for the written and precise calculation that in addition to the matter of plants we also do so much autocad
hi it is not that it seems wrong, more than anything else I am always insecure to deliver tablets even with a minimum error, having also a very competent and demanding prof, however many thanks of the approval tomorrow I will make it in sheet a4, thanks so much of the help
hi is not that it seems wrong, more than anything else I am always insecure to deliver tablets even with a slight error,
You're not in class and you're not delivering a task.
I would like you to be clear about the forum and how it works; you make available to those who read all the information necessary to discuss a problem: requests, doubts, sketches made with paint or with the stick on the sand of the cat, technical specifications, stop points not editable, and their ideas. Then we start, there is an exchange of views, of views because everyone has its own work experience and studies, of testardaggine, more or less caustic answers and you get to a solution together.
Perfect! Thank you so much, I usually come across people who only care about the final result, never knowing the hard work behind it, but the hard work if done with good advice is halved! Thanks again
Okay. tomorrow, when you make the table, be careful about the direction of the arrows of the section, because the one you posted imposes the right direction.
to this link find some dispensers on the technical drawing.
on the pdf dedicated to the sections to pages 5/7 you see how it represents the change of plan of a section, as specified wert
