antopippo
no discharge is not perpendicular to the axis of the piston. The candle is in the center. and thanks for the advice on the 7 travase. Now I finish the whole project first and then I change it because I am tight with the times for viqs of many checks. but I don't know how to calculate the harmful volume. I know how much it must be and how to calculate it though having the carter and using a liquid. How do I do theoretically?Good job, good job.
a couple of questions: The exhaust duct, if I understand correctly, does it have the axis on the same plane as the engine shaft? so the entry into the pump casing is at 90° compared to the exhaust duct?
the 3rd travase is at 180° from the exhaust light and its fluid vein you lose it immediately from the discharge, even if you can make a well arranged expansion chamber, but you know it well. If I can afford it, you should raise the lower edge of the third travase to improve the flow from the main beams.
I see a very thin traversine and, even if it is exposed to the fresh gases, it is a very "risky" point, so you should definitely work a bit on the fittings of the corners of the beam lights, otherwise....you always hold a couple of fingers on the clutch! ? ah no... you said that the engine goes on a kart. when "sail" the wonderful two times of the bike went on the ground. karting is a little less dangerous. ...
I don't know how you're doing the carter, but when you have something you want to share faces, maybe we can give you a few tips. the volume you call the carter's harmful, obviously depends on how you draw the engine shaft and the carter itself, but assess the volume change for each shaft rotation board is not difficult, you can also do it with an excell sheet. I would design first biella and piston, then the carter (and its volume variations) comes accordingly
a last curiosity: did you put the candle at the center of the burst chamber?
