Why models with surfaces?
attach the file without requiring it every holy time halves the time of the answers.
I'm sorry, you're right, I'm gonna attach the .step file!and why if you have to make a folded sheet do not use the appropriate functions?
Again. .. why models with surfaces if you need to create a sheet?the surface would be insulation on the sheet, I need to reverse engineering on the surface to create a sheet!
because insulation is formed by a sound-absorbing layer and a layer of aluminum sheet so I need development to cut to size, I attach the sw fileAgain. .. why models with surfaces if you need to create a sheet?
Why don't you attach the solidworks file?
aluminum sheet what thickness does it have? Do you need holes or no holes?because insulation is formed by a sound-absorbing layer and a layer of aluminum sheet so I need development to cut to size, I attach the sw file
write in the profile the version of solidworks so you avoid trying to open file versions not compatible.a layer of aluminum sheet so I need development to cut to size
thickness 1 mm, I need with all the holes indicatedaluminum sheet what thickness does it have? Do you need holes or no holes?
Sorry, the version is sw 2020! because it is a special insulation, comes out a sheet roll+coibentation+aluminumwrite in the profile the version of solidworks so you avoid trying to open file versions not compatible.
Then, I am hard to understand, but explain why to make a sheet use the surfaces instead of the dedicated functions?
What do you mean by cut on yourself?plate and insulation attachment: first figure original surfaces, second I copied the surfaces, third cut on themselves, fourth thickness and converted into sheet metal.
I think that in one way or another you can do it with sw.
I created something.What do you mean by cut on yourself?
non riesco adunile using quel commandI created something.add us to join surfaces as suggested @massivonweizen ...Taglio di superficie - 2016 - Guida di SOLIDWORKS
help.solidworks.com
