problem window layout
  • Thread starter Thread starter rickysavino
rickysavino
Good evening,
This morning I opened this autocad file and I find myself, in all layouts, this situation (photo1).
I've tried everywhere to fix things, I've been looking online... no.
I'll explain. I see in light gray the texts and the lines of the window and the scale seems to me "changed" (photo2) - in the sense that I usually hold 1:1 and every time I change it always returns like this.
If it happened to someone, can you explain why?
Ricky.
problem scale:
you did not save the printing settings in the drawing. once set click on "apply to layout"
the other problem you have not explained what is; to know what is a problem you need to know what should be the result.
I see in light grey lyrics
in the image are black segments
I see in light grey [cut] the window lines
e sarebbero?
The scale seems to me "dischanged"
based on what parameters?
maybe invest a bit of time to explain well what problems are, such as results to get and how you manage drawings
problem scale:
And what?
Thank you. I work on it. I wish I could solve this problem alone... If I can't get help... .
