meccanicamg
if at the exit of the gear motor there must be a pair of pulleys with belt or two pinions with chain will make the appropriate calculations of the straps or chains. on the manuals of the serious builders there are formulas to check for example the chains according to all variants.then my question continues to be this, if besides the choice of the gear motor outside the gearbox you can apply further gears? Usually in conveyor belts are applied chain gears or seldom belts but never dense wheels, from what I saw in industrial machine explosions I found that are rare applications of gear pairs further applied to the gear motor to the same....
