replacement cart
  • Thread starter Thread starter pietro2014
hello if you have many files already made, I use this rule, and if I remove hand to a file made with old templates, I click and change. You have to have a template with the paper you want to put, and then replace the paths.
Code:
public sub main ()
    'check title in active document
    try
        dim odrawdoc as drawingdocument
            odrawdoc = thisapplication.activedocument
        ' check if drawing deferupdate state is true
        if not odrawdoc.drawingsettings.deferupdates = "false" then
           'showerror("can`t change title because drawing file is deferupdate")
            exit sub
        end if
        'sostituisco i simboli nel disegno
        try
            deletesymbols
            'copysymbols
        catch
        end try
        dim title="cartiglio-2019"
        call replacetitle(title)
    catch
        msgbox("errore durante sostituzione cartiglio")
    end try
end sub
sub replacetitle(byref title as string )
    dim template = "c:\impostazioni_inventor\2018\templates\2019 standard.idw"
    dim otemplate as drawingdocument
    dim osourcetitleblockdef as titleblockdefinition
    dim onewtitleblockdef as titleblockdefinition
    dim osheet = odrawdoc.activesheet
    try
        'apro il template
        otemplate = thisapplication.documents.open(template, false)
        'aggancio la definizione del nuovo cartiglio
         osourcetitleblockdef = otemplate.titleblockdefinitions.item(title)
        'copio la definizinoe del cartiglio nel nuovo disegno
         onewtitleblockdef = osourcetitleblockdef.copyto(odrawdoc, true)
        'chiudo il template
         otemplate.close
        'msgbox("tentativo di inserimento cartiglio "  & title)
        'inserimento cartiglio sul disegno
'        dim i as integer
'        dim intprompts as integer = 0
'        for i = 1 to onewtitleblockdef.sketch.textboxes.count
'            dim otext = onewtitleblockdef.sketch.textboxes(i)
'            if (otext.text = "my_prompt")
'                intprompts = intprompts + 1
'            end if
'        next
        'msgbox ("trovati " & intprompts & " messaggi prompt")
        dim oprompts(2) as string
        oprompts(0) = ""
        oprompts(1) = ""
        oprompts(2) = ""
        osheet.titleblock.delete()
           osheet.addtitleblock(onewtitleblockdef,,oprompts)
        'msgbox("title block changed to " & vbcr & title)
    catch ex as exception
        msgbox("errore: " & ex.message)
    end try
end sub
sub deletesymbols
dim odoc as drawingdocument = thisdoc.document
dim osksymdefs as sketchedsymboldefinitions = odoc.sketchedsymboldefinitions
dim osksymdef as sketchedsymboldefinition
for each osksymdef in osksymdefs
    if osksymdef.isreferenced = false then
        osksymdef.delete
    end if
next
end sub
sub copysymbols
            dim strselectedstamp as string = "result2"
            dim strstamplist as new arraylist
            dim strstamprequired as boolean
            strstamprequired = true
            strstamplist.add("cartilgio-2019")
            'strstamplist.add("x ossitaglio")
            'strstamplist.add("test")
            strselectedstamp = inputlistbox("please select a stamp.", strstamplist, strselectedstamp, "stamp selection", "available stamps")
            dim strdrawdoc as inventor.drawingdocument = thisapplication.activedocument
            dim sourcefile as string = "m:\_impostazioni_inventor\2018\templates\2019 standard.idw"
            dim strsourceidw as drawingdocument
            strsourceidw = thisapplication.documents.open(sourcefile, false)
            dim symboldef as sketchedsymboldefinition
            dim copyfrom as sketchedsymboldefinition
     try
            for each symboldef in strsourceidw.sketchedsymboldefinitions
                    copyfrom = (symboldef.copyto(strdrawdoc, true))
            next
messagebox.show(ex.message, "title")
end try
            strsourceidw.close()
    end sub
I just needed the code piece to copy the symbols, thank you! 😅
regarding the path of the standard.idw file, you can recover it through this command:
Code:
sfolder = thisapplication.fileoptions.templatespath
Good morning
Thanks adahm, I read everything and I tried to put only these two lines, but it doesn't work. .
I just wanted to replace/update the edge and the cartilage
