mirrored part with relative table
  • Thread starter Thread starter andrea1974
p/n product number. logical codes must be different even in case of a particular specular without modification. to remove the holes a very comfortable feature is the "face case", look that the option "cancella and patch" is selected
Did writing identification number or code remove suspense from surgery?
methods are different from the most trivial extrusion (which could be tested independently on the moment), to the face erase (which can be used on simple holes), to the configurations (which you have to know how to use them).
I have already explained other times that the derivation of the details is unique, that is, the modifications propagate from the father file to the son and not vice versa.
@ andrea1974 is appreciated a formulation of questions in an understandable way
@massivonweizen p/n = part number.
logically, if a mirrored part becomes somehow different from the original part number must be changed.
I abort those solutions with the same part number and notes on the table "on the left side do not make holes".
@massivonweizenp/n = part number.
the question concerned a specific problem concerning the functionality of solidworks and not on the management of codes
I assume it's been a while, solid right-hand with right-hand table. solid b with left panel hooked to the solid dx as it said massive. But on the sx table, it's not good. How do you change it?
question. I have a base with many quoted views dx. I have to quote it left. I proceed as described above. But if inadvertently you have erased the main view during the quotation you need for the mirror, can you restore it?
Otherwise I can't mirror it right anymore?
So the problem I have is:
solid dx with table dx
solid to left with table to left.
on the right-handed stationery appears written on the drawing code a dx. perfect but
on the left-handed folder appears written on the drawing code always to dx instead of to sx.... How do I change it? I can't do it. if not by hand forcing the cartilage that you should not do.. .
I can't send you files with the boards... I send you solids
on the table 31005001 appears 31005001 just
on the table 31005025 always appears 31005001 wrong. .
Now I don't dare open it because I'm working with 2017. did you check the interrupted link option, during creation?
However, without opening it, for the assemblies, personally, I always prefer to reconstruct the mirrored version....1684307835409.png
i 1684308696449.pngIt's all right in the 'assieme, the problem will be in the drawing sheet. check the link to the property if you call code.
we tried to call up code or remove it but nothing happens, but they tell me to contact the pdm because it may not be a solidworks problem but the pdm that messs up the program. .
but here we talk about parts.
as it said andrea1974, now that I think again, even in the company where I worked before, the components obtained through "specchia part" were abolished because they gave problems with the pdm.
Did you write code in the drawing sheet as well? or in the pdm ...of times it does not recognize if written different. ..code or code or code does not always recognize them as equal.
tried both cases.. Nothing.
