reggio
hello, we always happen singular requests, in this case from the france ask a quote for a conveyor belt suitable to move debris collected from channels and rivers where everything falls.
with a large rake lift the debris from the river and must be removed.
the material that is loaded on the conveyor belt is various: leaves, sprigs, cans, cans, but the heavier and/or sharp objects are carcasses of boars and trunks that are lifted up to beyond a "h" height " and left to fall from the opposite side on the conveyor belt.
what I basically have to do, is verify the single purple pin (roll axle) and dimension it, assuming that
- sooner or later the boar or trunk will fall at the tip, on one side of the tape, on one roller (on the less elastic point - maximum load)
- the falling body will be "medialy" rigid (and will stop in ... how do you estimate the stop time? )
- we neglect (if possible) the deformation of the boar or trunk and rubber coating roller (which I will definitely go to predict and add) not to complicate too much
- We consider one body in fall
I, already knowing of wrong, I would like to translate, the energy accumulated by the mass during the fall in kg and then verify the purple pin (or anything else will replace it) as if it was subjected to simple compression ..
However, in my head, I imagine putting on above a scale that can store the maximum weight during the impact and use that number as a reference.
I would kindly ask you for help
- understand and calculate the "weight" of the impact on "balance"
- understand and verify the roller ... with the correct method whatever it is
again, please try to explain how if I were a 7-year-old child, without taking anything for granted and explaining the various passages and reasonings
"I'm a wild boar, and I'm afraid they're feathers. "?
