Fabietto
edit. ah no, the upper jaw is double.. Maybe to parade the chestnut from the teeth. .We have to put an extraction point under a spring and we have to patent it!![]()
certainly is a great exercise to keep the mind active (for those who have nothing else to think about - hence my consideration on being retired).but if the professionals of the boilers have pushed the builders to the realization of the industrial cutters, (see the fairs), I too in my little one, can think to simplify and make this operation more secure, even for only 15-20 chestnuts at a time.
Um, then I'm wrong to say I'm wrong. .as good scholars, always seek, that then I will tell you: you have seen well!
You wrote what I didn't dare write!certainly is a great exercise to keep the mind active (for those who have nothing else to think about - hence my consideration on being retired).
It's just that maybe one reads the title of a post and thinks maybe he can help, a point of view. and instead you find yourself reading the puzzle week.
the thing that (personally, be clear) irritates me a little is the "indovinello" style.
because I have already read you in other similar discussions (always with the riddle), to me comes a thing like "I know, we see who is at my level", from "maestrino" if so we mean.
it will be a personal sensibility probably, but personally I do not find it in accordance with the spirit of a forum, which mainly aims to help those who are in difficulty/impasses, rather than to do "to those who have it longer".
then probably (I would say almost with certainty) I will be wrong, but it is only to represent you "what" can come to those who read you.
peace and good.
you can also put another support, or a handkerchief between base and vertical part, but this is not a problem.I would put another support
the blade is in the correct position, central and at the right height.rotates the blade 180 degrees.
the cylinder rotates only, while the fork is fixed with two screws on the cylinder, in axial sense.how is the cylinder fixed with the fork against the axial movement?
@cristallo, I didn't ignore you but I waited for all your supporters to arrive.certainly is a great exercise to keep the mind active (for those who have nothing else to think about - hence my consideration on being retired).
peace and good.
You know me little, very little. here I have many more detractors than supporters. and above all not in this section, in which I am only a poor reader and I do not understand almost anything.@cristallo, I didn't ignore you but I waited for all your supporters to arrive.
Of course I know.You know there are people who have a problem, but they don't get any answers?
you know that others start a discussion, then they interrupt the problem, why didn't they get enough stimuli?
follow the people who, in order to acquire posts, give evasive answers, mistakes technically or just to contest, without proposing anything?
you know that "competent" people instead of saying: In my opinion, do they claim that this operation cannot be done, then be denied?
You know that almost always, even if required, most proposers, while receiving all the best suggestions, does not show the solutions adopted?
Do you know that there are people who give the soul, to quickly propose suggestions, tables, formulas, drawings, photos etc. even at night?
you know that other people, with various directions, but with thirst to know, do anything to capture the defect, which is visible but not identifiable?
and you think that presenting a small unpublished project, with a mistake to be sought, is not a positive stimulus, but even contrary to the spirit of the forum?
see, I would never dream of telling you how to use a bearing or how to fold a sheet, because my knowledge in mechanics shatters absolute zero.follow the people who, in order to acquire posts, give evasive answers, mistakes technically or just to contest, without proposing anything?
I don't prefer the puzzle week. I said the Yours post is week enigmistic. Didn't you really understand what I wrote? (note the difference I say "you didn't understand what I wrote", to someone who says to me "you read bad... you can't read... you can't answer. You make preconceptions... ").Look, there's no "master" in me like you say, who wants to show that he's superior: You read bad and you can't read between the lines.
I studied, worked a lot and learned a lot, but I'm still studying, even after dinner, to be ready to help those who need it.
you do preconceptions about the style of my writing, instead of looking inside, but then you too have escaped my proposal, prefer the puzzle week, where the questions are more difficult, because the easy you can not answer.
I don't want to tell you, but someone at first followed you, then the discussion died, most likely because of lack of interest.I have to point out where the technical defect is, I know that you don't care, but others do.
install the camtasia program and convert your video to an animated gif.Unfortunately the video is not visible because not supported, I still have to learn to convert it.
