IBWorks
Good morning to all, I often fail to share a sketch because I get stuck in quotas even if the sketch is not yet completely defined. place an image below to better understand.
As you can see, the height 74,64 is in blue even if that part of the sketch is still to be defined and its lock is gray and does not unlock. I happen quite often, but I don't find a logical thread that pulls out this problem.
solid edge 2020
As you can see, the height 74,64 is in blue even if that part of the sketch is still to be defined and its lock is gray and does not unlock. I happen quite often, but I don't find a logical thread that pulls out this problem.solid edge 2020
