quote bloccate
  • Thread starter Thread starter IBWorks
IBWorks
Good morning to all, I often fail to share a sketch because I get stuck in quotas even if the sketch is not yet completely defined. place an image below to better understand.
1705325215720.pngAs you can see, the height 74,64 is in blue even if that part of the sketch is still to be defined and its lock is gray and does not unlock. I happen quite often, but I don't find a logical thread that pulls out this problem.
solid edge 2020
View attachment 70056As you can see, the height 74,64 is in blue even if that part of the sketch is still to be defined and its lock is gray and does not unlock. I happen quite often, but I don't find a logical thread that pulls out this problem.
solid edge 2020
sincerely I can't even figure out what the top reference line is connected to, if the extension is not connected to the edge.
which upper line is not connected to the edge? They are all bound, the problem lies in the virtual intersection at 74,64
solid edge 2020
He also does it to me on virtual edges in sketchy environment. Maybe it's a kiss or maybe it's on purpose. If you have to quote exactly that position, put a "point" entity and share that, then you have to tie the segments to the point.
ok grazie.
