automatic axis lines on board.. .
leggera
Good morning.
I am making a table where we need to put small quotas using axes as in this case:
1705575116129.webpin another view I think I have devised the axis and cannot find the function to make it visible again.
Is that possible?
the axis you are looking for is a origin or comes from a sketch line?
is one of origin derived from a revolution.
present when you open it with the dx button and remove it from the display?
Here I think I have removed the check and now I don't know how to view it again. . .
I usually do filter select priority part
parte.webptouch the component -> button dx -> located in the browser
I open the tree of origin and touch what I want to include.
hi beppe,
I think we're talking about two different things.
I meant in the table environment when you open the dx key and decide to hide a line.
1705651179686.webpHow do you review it? ?
in fact in the 1st message to put a reduced quota I put the axis with the function button dx >
automatic axis lines, then I guess I devised the axis and I don't want to see it again.
I usually to make these odds I identify my part/aid in the browser and select the plan/axis of origin that I want to "include".
a fly made the quota select the plan/axis and remove the visibility (if I remove "includ" the quota that inherits the reference jumps).
if I want to make the reference axis/plan again visible I do the same procedure, i.e. I identify in the browser the part/axis from which the reference is issued.
the axis I need to make the quota, having hidden it and not knowing how to make it visible I do not know how to create it.
