(autosez 2) soil sections and profiles - automatic extraction
I don't know how to thank the author of this script that has greatly simplified my life! Thank you so much!
good morning, is it possible somehow to convert the .vlx file so that it is also usable with zwcad? options that give me .vls (besides .lsp and others). Thank you.
I press that I just recorded at the forum. I tried to look in the various comments but I didn't find how much I was looking for. after creating the triangulation of the points with the appropriate command, is it possible to correct the triangles with a line/polyline of discontinuity? Thank you.
Hello and welcome. this is the discussion of autocad, it is not among your software. . .
anyway it is not clear the question, do you want to cut or move the triangles?
I intend to cut/optimize the triangles in correspondence of a discontinuity line, for example a road, a wall, the edge of a shoe.
I always used the lisp with great success and satisfaction.
for some time now what you see in the two screenhots attached.....
the lisp is interrupted and does not produce fiction.
Does anyone know how to help me?
I autocad 2022 and used the lisp earlier with that version.
... what you see in the two screenhots attached.....
if you have not already solved search for the autosez.dat file in the path you can read from the localrootprefix variable and delete it, then reboot autosez
Hello everyone,
I have just arrived at this site and used the autosez file successfully to which I congratulate those who have processed such valuable utility. I wanted to ask if there is a lisp that from the tinc extracts the x,y,z points (a quotated plan consisting of only points in short). thanks and congratulations to all.
Hello and well found.
would it be possible to automate the process to extract multiple sections simultaneously (selecting them in sequence on the planimetry), instead of recalling each time the lisp to be extracted a single section?
I realize that it is very complicated and I thank those who will respond.
Unfortunately, it's what I can do, I'm sorry, but I can only do fast things or even need my staff. . .
consider that, drawn a section, just send + forward to draw another.. .
Hello Jan Paul,
What do you mean by "relancia autosez"?
I found the file you said, I deleted it and then with autocad always open I did appload and I loaded autosez but it does not still generate me the fawning of a 2d polyline (see screenshot attached).
Should I close autocad, delete the file and then relaunch autocad and reload the lisp?
yes, otherwise the variables of the old file remain in autocad memory.
Nothing.
I can't make it work.
I deleted the autosez.dat file, cleaned the files of the pc, turned off the pc, restarted, launched cad, made appload of the lisp and however something does not work.
Can't there be a font problem?
