Keep in mind that by finished operation, they are the transients in acceleration/deceleration that make more consumption because at regime it does not need power. if you use direct engines it is difficult to estimate real acceleration.In this case I have to deal with a product built by third parties that we are not aware of their design method, and anyway I looked on the forum but I couldn't find anything.I apologize for the words written wrong... the concealer tonight is crazy.
know how
everything
a lot
between the fundamental data lacks the type/pass chain. number of rollers, size of the neck....I guess if you see my picture. . .In this case I have to deal with a product built by third parties that we are not aware of their design method, and anyway I looked on the forum but I couldn't find anything.
I now set a couple of data if they can be useful:
1400 rpm of the engine
0,75kw
reduction ratio i=40
sprocket on reducer z=15
sprocket on roller z=12
roller diameter 89mm
weight of a roller 13kg
chain 5/8 simple 24 steps on the wheel, 27 steps from that conducted.between the fundamental data lacks the type/pass chain. number of rollers, size of the neck....I guess if you see my picture. . .
need some extra data.
What do you propose to us as a calculation?correct. In this case it may be that the ac motor during the start is subject to a couple in addition to its nominal capacity for a certain duration resulting in increased temperature. if the start is limited there is no problem because, if the operation is continuous, the ventilation of the motor can re-establish the thermal balance, if instead we are in the presence of a service characterized by a high intermittentness, it is necessary to preview of the thermocouples in the winding to safeguard the functionality of the motor in case of excessive overtemperature.if you use direct engines it is difficult to estimate real acceleration.
According to me here should not be considered the weight of the rollers as they are not part of the material to be transported.the total transported weight is 1400 kg and the total weight of the rollers is (20rolls•13kg/roll=260 kg). then:
invoice=(1400 kg+260 kg)×0.3=498 n
here instead I agree because their mass influences the force required in acceleration.the total mass is 1400 kg+260 kg=1660 , therefore:
f acceleration=1660 kg×1 m/s2=1660 nf_{ acceleration} = 1660 \ kg \times 1 \ m/s^2 = 1660 \ nf acceleration=1660 kg×1 m/s2=1660 n
In fact, you are right even if you often put it in the stem as an "addition factor". in acceleration does inertia, in static does not affect.According to me here should not be considered the weight of the rollers as they are not part of the material to be transported.
is reasoning correct?
