how to repair the grooves on a tree generated by the seals (parail)
  • Thread starter Thread starter gerod
in my industry we send components to undergo material carryovers to obtain superior durability or to recover damaged trees:
I have no idea the costs.
for lip seals an old trick to mitigate the erosion problem, was to work the seat of the seal slightly disassed by the cylinder on which the lip insists, so as to increase the crawling area and make it less localized.
Thank you, they could go well for the new tree so as not to damage it.
Thanks for the report.
at this point then you could do a carry with the rods of the castolin at low temperature to fill the grooves, return only to bring in diameter and then use the rings proposed by @ focus
It could be an interesting solution, I like it, but they're making them by bringing more thick rings.... cross fingers
Here's the job.
I'm gonna take him back and see if he does his job!
thanks to all for suggestions.
