Dylan
I often get put into the table of rather large pieces.
Every time I start putting down quotas I never know what will be the best way to share everything in the most understandable and complete way.
I'll explain.
if I have 200 holes and little more (and a perfect math senno' ciau..) maybe I do the classic hole table (even if when I go to put id on the ciau holes they overlap all and step endless moments to give it a sense...).
if the holes are not a marasma maybe quoto with the automatic quotation that is messed up a little only when there are a little too many nearby holes.. But it's obvious.
the beauty comes when I have to do the details. Open up. Will I or will I not?? ?
I'll take the detail.
I create the view of detail. Bam appears to me in scale 5 meters from the edge of the cartilage, and I can't take it off. Now I have to put down quotas.
I would like to be able to put down quotas (of course referred to zero piece) but I can't. zero is five meters and I would have witnesses of the gigantic quotation, not shredded by the detail view. Coordinated label. Close the hut. reopens the file of cad. applies the labels, save, reopen, update, hope you do not funeral of the quotas (when the quotas become white corpse) and apply the labels. And don't forget about anything, you need to remake the string. if you have 50-60 vien on an incredible mess. then you notice that the labels do not apply in the view in detail.
in detail I would like to understand how you quote the views in detail. . I believe and I am sure I have some gaps and surely with some cunning or what else you do.. But how? then.. how do you hide the terna of a view in detail? ?
I expect someone in honor and raison of true enlighten me and subtract me from ignorance. or simply suggest to me a solution "the classic faicosi'chevienbenelostesso that in a more or less professional way let me export to the plotter drawings worthy of being called so.
dylan
I'll explain.
dylan
