ecomusposta
Hello everyone, unfortunately for a couple of days to this part I was forced to change hd where my inventor 2009 resided and take me an old hd where there was installed sw 2007. Unfortunately, the need for work to create a deformed spring (which therefore does not follow a path along a linear axis but rather along a spline determined by me) with its relative animation, grafted between 2 cylinders emptied inside and placed in angular position between them we say to 45 degrees, (not exactly 45 but almost). I on inventor created through the coil command the spring with relative circular section determined by me, then on animator modify or the number of coils or adapt the compression surface, but I always and only made linear springs.
Now you create the need for this animation of this infamous deformed spring (to create the spring no problem at least I believe, I create my spline that would be the path to follow, then my circular section and then through sweep command and imposed torsion revolution or laps or torsion degrees.
good but for animation? how should I move it or at least adapt it to the surface under the compression force?
looking for this forum I found this link:http://www.cad3d.it/forum1/showthread.php?t=23492&highlight=molla,
but ahime having the 2007 version I can't read it, I also read another discussion in which he cited an adaptation to the primitive sketch of the spring, but shit but here the spring is not linear.
in any case I thank you in advance for the vs. I ask the moderators in advance whether they believe this debate is open or useless. Thank you all.
