apple & nx
  • Thread starter Thread starter The_Matrix
I would say that here almost no one is an apple user, since the vast majority of software for mechanical design turns on win.
I am in trouble I am untente mac with operating system 10.10 yosemi and I do not know how to learn nx 9 and I do not know if the 10 nx is located or works on apple :(
but sorry, with what costs a cad like nx you feel the assistance what it tells you. I don't think you'll find anyone here who uses nx on mac, if not some dealer/technical siemens. Incidentally I fear that you will find few even in the world of mechanical design.
as I told you if you are interested in the 3d in the field of mechanics passes to windows, regardless of any consideration on the superiority or not of a know regarding the other, totally useless considerations as to work you first delete the necessary software then, at equal availability on several know, you make the assessments of the case on the know. the procedure conducted on the contrary has to do with questions of "faith" and not of real necessity to use a certain instrument.
Unfortunately now I have this car so I have to adapt when I have to change I will evaluate at that time is that I use many applications for mac. It's a long speech now I have to try to find a solution while I sent siemens an email let's see they answer.
I know someone who uses a cad in the virtual machine, and says it's okay. uses vmware, which I don't know if it exists for macintosh.
That's the only one.
But do you know if version 10 is out?
that is compatible with my operating system
p.s.: I looked at the site: for mac they have the fusion 7 "pro" with which, they say, you can turn quietly solidworks.
I do not have much familiarity with mac, but on the simens site only nx10 is certified for "mac os x 10.10".
at the limit you should pass through a virtualization system (I used parallels in the past, but surely there will be other ...) and install windows. Incidentally virtualizing windows would allow you to take advantage of the nx interface for windows that in my opinion is definitely more performing than that for osx / unix, certainly on a virtualized system the performance is penalized .
Good luck!
