apply 3d model material withdrawal
  • Thread starter Thread starter Robert Tutu
Robert Tutu
hi to all, I would like to ask you politely how to apply the withdrawal of 1,65% to the plastic piece that I have to model, the material is latistat_52_7_02 (pp antistatic). having never done it I don't know how to proceed, I use I create 2.0
I attach image of the piece.
Thank you very much to those who will help me.
cordial greetings,
Robert
if you have pro/mold there is the withdrawal command.
otherwise you can arrange but with some limit with the model scale command.
Look for them in the help I use wf4 and I don't know where I'm at.
careful that with model scale you lose the original file so I would make a copy _1.65 and I would apply on this scale , unfortunately it seems to me that the command does not apply on an inheritance so you will lose association between the piece and the piece with withdrawal.
I did a test and it's like this for me but you also check.
cordial greetings,
Robert
Try to see if this video can help you
video factor scale
but do you have to design a plastic mold? because I didn't understand for the first time what you mean, the withdrawal 1.65% then I think when you write it in the withdrawal command you have to write 1.0165...I may have misunderstood... : )
