autocad quota system
  • Thread starter Thread starter teklast
teklast
Hello everyone,
exists a version of autocad, or a clone, (but also an application) that allows the quotation in "tekla style"?
by "tekla style" I mean the possibility to insert (and change) quotas with the "dynamic" that tekla offers in the manual quotation of the pieces.
I forgot, I use an obsolete version of autocad (lt2002), but for the use I make it goes even more than well.
but there was the possibility of giving brio to quotations would not be bad...hehehehe. . .
Have you at least tried to download a trial of the latest autocad versions to see what's new on the front of the odds?? ? :confused:
What dynamism has tekla? Do you explain it or do we have to go on trial?
1) possibility of continuous quotations without the need to identify the points compulsory in one sense, but (wanting), also clikkando the points non sequentially.
2) automatic positioning of the quota texts to the right/left/up/under/under/under the quota line itself, without subsequent manual intervention
3) adding/removal of a quota point (intermediate at a continuous quota) with automatic arrangement of the same quota
Of course, whoever tried tekla knows better than what I'm talking about.. .
I hope I've been clear enough
I just tried to install the trial acad2012 but the quotation system, gross, has not undergone significant changes
the quotation goes from point to point, it automatically changes if the "stiri", you can vary what you want from the property box.
clearly following a logical thread, I would say technical....
I know more! :wink:
half a day to me would not have been enough to deepen the topic quotas (new introduced in creation, modification, annotative quotas and especially in the styles of quota which you did not mention).
I probably didn't go into it properly, I confess,:finger:
exists in this regard, on the net, some documentation that illustrates the topic "quote" in acad 2012?
better if in Italian
I would say that if you want to browse the autocad help to the user manual section -> annotation in drawings -> odds and tolerances , you have enough to understand how the autocad quotation system works.
Thanks for the suggestion... I did it.. .
I found multiple options and special effects but what I really wanted to see (I return to my post n.4 http://www.cad3d.it/forum1/showpost.php?p=242834&postcount=4)
purtroppo non c' era :frown:
in autocad you can select in one shot only all items and generate quotas (even in a non-sequential way). you must select the symbol with the quotine that has lightning. I don't know if that's exactly what you mean.
just set the quota style with your preference.
I don't know what you mean about why you need to remove the quota without changing the drawing. Did you have the odds wrong?
if the thing is resulting in the modification of the design then with the associative quotas you solve otherwise take the grip and drag it to the new position.
thanks for the answers.
I probably only solved the second point.
good we
good we
We probably didn't understand what you do because we don't use teckal, but you will have to admit that you can use 10% autocad because from what you wrote more nin zai.
starting from the creation of a style of quota... here a list of variables... .
Code:
dimaso off creates quota objects
dimstyle iso-25 current quote style (read only)
dimadec 2 decimal angular figures
dimalt off alternative measurement units were
Select
dimaltd 2 decimal digits for measuring units
alternatives
dimaltf 25.4 scale factor for measuring units
alternatives
dimaltmzf 100.0 alternative subzero factor for odds
Metrics
dimaltmzs suffix alternative subzero for quotas
Metrics
dimaltrnd 0.0 rounding value alternative units
dimalttd 2 decimal digits for alternative tolerances
dimalttz 0 suppression of zero tolerances
alternatives
dimaltu 2 alternative units
dimaltz 0 zeal suppression of alternative units
prefix and suffix dimapost for alternative text
dimarcsym 0 symbol length arc
dimasz 1.0 arrow size
dimatfit 3 adaptation arrow and text
dimaunit 0 format of angular units
dimazin 2 angular zero suppression
closed dimblk full arrow block name
dimblk1 arrow first arrow block name
dimblk2 arrow name of the second arrow block
dimcen 0.0 center marking size
dimclrd 1 (red) color of the quota line and line
Director
dimclre 1 (red) extension line color
dimclrt 3 (green) color of quota text
dimdec 2 decimal digits
dimdle 0.0 extension of the quota line
dimdli 1.0 spacing of the quota line
dimdsep . decimal separator
dimexe 1.0 extension over the quota line
dimexo 0.0 offset from the origin of the extension line
dimfrac 0 fraction size
dimfxl 1.0 line extension fixed length
dimfxlon off active line extension fixed length
dimgap 1.0 space between the quota line and text
dimjogang 45 angle reduction radius
dimjust 0 justification of the text on quota lines
dimldrblk closed full name block Governor
dimlfac 1.0 scale factor for linear units
dimlim off generate quota limits
dimltex1 byblock line type extension 1
dimltex2 byblock line type 2 extension
dimltype byblock type of quota line
dimlunit 2 linear unit format
dimlwd -2 thickness quota line and guideline
dimlwe -2 thickness extension line
dimmzf 100.0 subzero factor for metric quotas
dimmzs suffix subzero pre metric quotas
default prefix and suffix dimpost for text
Share
dimrnd 0.5 approximation value
dimsah on split arrow blocks
dimscale 10.0 factor of general scale
dimsd1 off suppression of the first quota line
dimsd2 off suppression of the second quota line
dimse1 off suppress the first extension line
dimse2 off suppress the second extension line
dimsoxd off suppress external quota lines
dimtad 1 place the text above the quota line
dimtdec 2 decimal digits for tolerances
dimtfac 1.0 scale factor for text height
tolerance
dimtfill 0 background text activated
dimtfillclr dablocco color background text
dimtih off text within extension lines
is horizontal
dimtix on positioning the text within the
extensions
dimtm 0.0 lower tolerance
dimtmove 2 shift text
dimtofl on force line within extension lines
dimtoh off horizontal external text
dimtol off tolerance of quotations
dimtolj 1 vertical justification for tolerances
dimtp 0.0 greater tolerance
dimtsz 0.0 line size
dimtvp 1.0 position the text vertically
dimtxsty quote text style
dimtxt 2.5 text height
dimtxtdirectionoff direction quota text
dimtzin 8 zero suppression of tolerances
dimupt off text placed by user
dimzin 8 suppression of zero
then passing through the association of quotas......
then pass them to the annotation scale. . . .
I'd say a read to the manual wouldn't really be a bad thing, or if you want some direct tips, make a video with the "magic quote" that we understand what it does.
alternatives
as I have already responded to the other user, the solver problem is only point 2 by establishing an appropriate quota style....
I don't know what to do with membership quotas.Thank you all for your effort to help me.to you, shape, however, I must say that the sarcastic tone emerged in that expression ("magic quoting") you could also save it.
blessed you who know how to use all those sw you have on your list...:4425:
If I have time, which I do not have right now, I will see to insert a video.
for the moment I pass and close wishing everyone good work:finger:
And he thinks I read the manuals. you have seen how much time I have to lose!
cmq to give you an answer on my sarcastic tone. . .
if you read your posts you will notice that everyone reacted a little :rolleyes: to your statements of the power of "your" software... You have to understand that if you write in a forum of another software maybe you have to put it a little different... for the series. . "I use autocad lt 2002 but I think I don't need anything else"between the lines you understand that you use it sporadically to pull 2 lines... And there's no reason why you can't debut then I read the news (in 3 minutes autocad for dummies) and it's not that there is much... obviously you will understand that who works there 8-10 hours a day you read help and manual is not so then agree with you... and maybe your evaluation on the software is a little superficial. . .
Of course you use a very high-end software (teckla) very dedicated to design (carpenteries etc etc.) while autocad is a generic software with which you can make carpentry, conception, artistic drawing, recipes of the grandmother....but this does not mean that a "particular" quotation can not be done even with autocad... Of course, to do this you have to know how to use it and not know so much for....
Okay, I take note that a diatribe was born, but my intention was not that.
If I have sinned I apologize.
I repeat, to avoid wasting useless time, I will publish a video as soon as I have time to do so.
soon
When I was a child, my neighbor was called a tecla... .
how long has passed!! : eek: :biggrin: :smile:
