teklast
When I was a child, my neighbor was called a tecla... .
how long has passed!! :
http://www.youtube.com/watch?v=9l9k3ndmxue:finger:Come on, come on.
I was with someone who was called tecla but dumped me, that's why I can never use tekla:biggrin:When I was a child, my neighbor was called a tecla... .
the insertion and modification of quotas in tekla allows a rapid management of the single quotas. I have not found software that has a flexible and dynamic quotation system like teklaHello everyone,
exists a version of autocad, or a clone, (but also an application) that allows the quotation in "tekla style"?
by "tekla style" I mean the possibility to insert (and change) quotas with the "dynamic" that tekla offers in the manual quotation of the pieces.
thanks to the testimony bimchecker:finger:.the insertion and modification of quotas in tekla allows a rapid management of the single quotas. I have not found software that has a flexible and dynamic quotation system like tekla
in autocad as in tekla you can lean on programming to create new commands, for autocad of using the lisp while for tekla you can use the dotnet language (.net)thanks to the testimony bimchecker:finger:.
I dreamed (and hoped) there was some "travel" for the autocad quotation system that made it similar to that of tekla but, reading your post, maybe there is.
I'm still waiting.
the solution obviously there is, with lisp or vba or .net we make it mark even below... but the user uses a lt version of autocad so does not support programming.in autocad as in tekla you can lean on programming to create new commands, for autocad of using the lisp while for tekla you can use the dotnet language (.net)
If there was a solution I would have no problem migrating to a full acad versionthe solution obviously there is, with lisp or vba or .net we make it mark even below... but the user uses a lt version of autocad so does not support programming.
Sorry if I return to the topic but I wanted to try to use automatic quotas (those with lightning) on a couple of metal carpentry tables.I probably only solved the second point.
Are these quotas present in autocad lt?automatic quotas (those with lightning)
I honestly don't know. I have the full version.Are these quotas present in autocad lt?
how should they be used?
autocad lt 2012 has the command dimrapid; guaranteed to lemon!! What version do you have?when I write dimrapid in autocad lt tells me nonexistent command
dimrapid was introduced only in autocad lt 2011. Previous versions don't have it.I'm sorry, but isn't there a drop-down menu?
That sounds crazy. .
useful features to whom? Who does carpenters? It's not his job. then we are talking about lt, a software just over 1000 euros. What do you expect? coffee and brioches...suvviain the last two years we have not updated autocad because updates to the latest versions (from 2008 to 2010) have not added useful features and autocad has weighed in exponentially
That sounds like a good reasoning. I do not use the pastime to make the meat grinder, although virtually you could succeed. . .we are thinking of abandoning the autocad platform by going to carpentry-specific software that in addition to offering targeted tools that simplify work.. .
I agree with you. the 2012 version flies. It's faster than the previous ones and it's more productive. there are many small tricks that make it very quick to use.autocad is currently very light and allows you to do everything and more.
alt. I kept a car with xp to print from 500 but you tell me you can do it as a carcad?The last one. the "big" hp abandoned the plotter designjet 500. They practically didn't make the driver for win7 anymore, but they force you to the "share" mer... autocad solves everything autonomously and makes you print directly from the "model". Not bad!!
