Luigisasso
Hi, guys, I'd like to know how to vanish a hole in the carcad, could someone please help me?
make two tilted lines between them of the angle of devadinghow to wash a hole in autocad
So you're talking about modeling 3d. You didn't write it.Do I need to extrude the hole first?
Good. maybe learn to contribute usefully to your discussions; if in This is what you have solved report your solution so that others benefit, if you have not solved report the problem so as to solve it, if you let it back so that other users do not waste time giving advice on something that you no longer care aboutnext time I create a discussion in the autocad section
