autocad
  • Thread starter Thread starter Luigisasso
Luigisasso
Hi, guys, I'd like to know how to vanish a hole in the carcad, could someone please help me?
Why do you continue to write in an undedicated section explicit to the software you require help?
It's your habit to let go discussions that you opened yourself?
how to wash a hole in autocad
make two tilted lines between them of the angle of devading
Do I need to extrude the hole first?
So you're talking about modeling 3d. You didn't write it.
I am not practical to autocad 3d, but explain how it is conceptually possible to extrude a hole?
next time I create a discussion in the autocad section
Good. maybe learn to contribute usefully to your discussions; if in This is what you have solved report your solution so that others benefit, if you have not solved report the problem so as to solve it, if you let it back so that other users do not waste time giving advice on something that you no longer care about
