nicocaroli
Good morning to all, I write here in hope that someone with more experience than me can help me.
in preparation for a university thesis, I must dimension and analyze the hydraulic circuit of a bending press. machine data are:
- max force in operation: 200 tonnes
- toolbar weight: 4 tonnes
- No linear actuators: 2
- downhill speed of the tool: 200 mm/s
- max plate working speed: 10 mm/s
- return speed of the tool: 150 - 200 mm/s
- downhill run: 250 mm
- work run: 50 mm
- load maintenance time: 3 s.
the objective of my work is to analyze 2/3 possible circuits, simulate them on amesim software and then compare the results obtained to evaluate the pros and cons of each system. the first system to which I thought is that in figure, consisting of the feeding system, 2 double-acting linear actuators connected together to get synchronism, a 2/2 valve used as safety in case of power failure, a balancing valve to control the downward speed of the toolbar.
even if the system is a bit rough, would it be able to carry out the desired cycle or is there any error?
Thank you in advance who will be able to help me.
I don't know
- work run: 50 mm
I don't know
