alequatt
Hello, everyone. I have two half-sections of conduct connected by a bolted flange. inside the conduct flows fluid under pressure. I wanted to ask you if it is correct not to consider the axial tensions of mariots since there is no melt that closes the conduct. I also wanted to ask if the internal pressure (without considering the weight of conduct and fluid weight) has some effect on the bolting project. to be clear, if you have to size bolting only taking into account pressure, what formula should I use? thanks
