ciccino
Hello I am new and I am approaching the cad recently
the maximum I can do at the moment is to draw in 2d and then give the command for the thickness for the 3d
in company we cut and we incite materials and often arises the problem of knowing the weight of the finished product
use autocad 2010 or 2011 depending on the location
example
cut a plate 200 x 100 x 3 mm aluminum 5754 with some holes
they told me that it is possible with some commands or programming so that given the design you can get the weight of the piece
the weight I need for example to calculate the shipment and various and possible
If that were possible, would you explain to me step by step how to do it?
thank you very much in advance to those who will help me:biggrin:
example
