krissbetarr
hi guys!I ask for help on the design of an industrial automation cart. I know that this subject has been dealt with several times, but in other topics it seems to me that chaos reigns.
I have to choose engine and gearbox to move a 1000kg cart on four wheels. the questions are:
- the gear motor is to operate two wheels rigidly connected through the same axle. the torque that generates the gear motor is divided into two (between the two wheels) or each wheel receives the same torque generated by the gear motor being rigidly connected? I'm told you're splitting in two, otherwise you wouldn't have to balance the rotation, would you?
- according to the answer to the first question arises second. to calculate the time necessary to move the cart I go to divide the total weight for four (four wheels). after which I have many doubts. the strong torque would be calculated (hand applied mechanical book) mr = mv + tr = fvpr + tr where p would be 2500n (1000kg/4 turned into newton), fv the coefficient of dynamic friction, radius of the wheel, t friction force calculated as p*fs (fs coefficient of static friction) correct?
- then I would like to calculate the maximum torque applicable to each wheel so as not to slip and therefore have maximum acceleration. I would concentrate all the mass of the structure in the wheel and calculate the corresponding moment of inertia for a full disk, using the formula that I attach. Is that correct? Can someone make some light on these blessed dimensions?
thanks to who will help me
