sincerely you have not understood much of the problem you have..post maybe some picturesthen modifying the already done cartiglio if I want to change even the fixed writings in the grid I made edit sheet then change block but there is only an active block that is the sum of the others while the other separate squares and cartiglio are as disabled, inactive so that I can not change the block cartiglio where there are fixed writings, in the only active block are unmistakable I can only add new writings.. There's no way to just open the paper block to change it? Because I don't know where it is...
blocks can be useful or not, depending on cases. I as the vast majority of times I make multifoil tables, it turns out comfortable.I still think that making the block is not very useful, if you go to see the base charts of solidworks are all without the blocks, only rows and texts
