reggio
I imagine that you understand anyone to work on a part together and have to change it by comparing it to a measure perhaps with another part as in the example.
normally you click on the quota and change the number if you already know the desired size, or use the darts next to the quota to change it of 10 in 10 (or the step you have set), at this point if I want to see graphically where I arrive with that measure I must press the semaphore "regenerates the model with the current value" ...
would be convenient (but also logical) if you could have upgraded to each measurement change: Is there an option I don't know to tick or know a trick to do this?
