cacciatorino
I'm making a plate with laminated holes to mount ball recirculation skates.
once the hole command is activated and the type of hole encounters three problems:
1) the size of the lamato hole proposed by swx is at least imaginative, where do I correct them?
2) when I go to design geometry to place my holes, for example 4 rectangles as in the attached case, then swx does not let me use the tops of the geometries to put directly the hole for the fact that there is already a point in that place. for now I have not found better than putting the hole near, and then touch the summit of the rectangle and the center of the hole and give it the bond of coincidence. with 16 holes this takes away time.
3) If I want to quote the position of the rectangles (the quota 150 in the attached example) I find no other way than to put a construction point in the middle of one of the sides, but thus swx thinks that I want to put a hole, which I do not want. Do I have to resort to additional auxiliary geometries to put this quota "150"?
