close a solid
  • Thread starter Thread starter edoardo5782
edoardo5782
Hello.
I ask you a help to understand why I can't create a solid from these surfaces.
I don't understand why open edges are being reported that seem to be lines.
p.s. see attachment x rhino
the surfaces are closed but the problem is that there is a surface that is trimmed badly and by problems, try to rebuild it.
But why do you need a solid?
Hello and thank you for the tip.
What do you think is the surface to be rebuilt?
I would like to create a solid and then export it to step and change it with solid edge.
Now I don't have a rhino in my hand and I go to memory
is a long and narrow surface on the side of the van about half height
I solid edge don't know it but in step you can export it even if it's not a solid, maybe there's some kind of command the solid works create that could solve these problems
I understand... I think to fix the solid, I have to remove that small surface and make the flank again.
Can you recommend a quick method?
I'm talking about this.
rebuild it... I tried fast but the result is not good, there is to work a little more especially on the nearby surfaces side cabin
