color threaded holes
  • Thread starter Thread starter Shaba
Shaba
hello to all
Maybe easy question, but I can't handle it. .
is it possible to set that threaded holes are of a specific color?
example red
automatically, without the need to color them manually
better if you can set only the threaded part, and not the preforum
I saw the texture of the thread, but I don't like it
Thanks :cool:
you are right I forgot, 2016 sp3
insert it into the profile
no one who can pass me a set file properly?
Sept how? And if the color you don't like what you do that you can't change it, ask again? and all the other colors?
However try to feel the assistance and ask confirmation that it is a bug
was just to understand if in this way I discribe threaded holes
for assistance now I see how it works, I installed sw yesterday:)
As far as I know, and on the holes I think I have overturned the world, it is not possible to distinguish them with different colors one from the other, but I hope to wrong myself.
It is easier for me to put a discriminant in the diameter of the hole, for example 6,8001 (for m8); that tenth of thousandth always remains, even after export, so the cam can filter them by diameter and discriminating, indifferently from the color that sometimes goes lost according to who cares.
if your purpose is to see visual impact which threads are, I do not see solutions with the standard tool of the drilling wizard.
I just need to discriminate visually. .
in the previous cad I was used so
I felt like I was successful first, but then I lost the septect.
Now the boss stopped me for something, then I try again
Last hope is after making the holes of coloring them by hand, but it's what I don't like too much
which type of threaded hole usually uses
din, iso, short or long foreground? oppress all kinds?
you might think something to filter them.. . .
create an extruded block and insert all kinds of threaded holes that you could insert and post it, if it suits you, that the study...
Metric and gas holes, passing pre-light or I usually hold half the thread
example, hole m10x20 pre forum x25
Then there's a place
I'd like only the threaded hole to be red.
Thanks
as you have noticed the coloring of the features is performed for families, so you cannot discriminate the fillets from the lamature, etc.
I wrote you a macro, throwing it with the open part (together it does not work), scans the features, if you find threaded holes color them red.
It's fast and you don't even know.
I think it can do to your case, it could also be extended to other holes, coloring the laminated holes, etc. of different colors.
for example, I customized the database with new holes, I also created (programmed) an alternative menu to the drilling wizard, leaner, faster, always for the issue of being pre-eminent and safe of what I do without having to think (e.g., the electroerous plug is always passing, I don't have to tell you, the lamatura is always passing for 99% of cases); during the creation of the hole with my menu I go to change the color automatically, which with the drilling wizard is not possible, I do it myself.
Believe me, it is very beneficial to have colored holes, it is immediate for anyone working with tea to understand the type of hole without having to go into detail, and then it also remains in conversions (usually).
Besides, if you create a calloutformat.txt to doc you earn so much even at the table... but here we go out argument.
Try it and see if that's what you need.
I also attached your part where I removed the automatic coloring of the holes and added another 2 or 3 holes so you can test the macro on the same piece.
I tried it fast, very nice!
Congratulations! ;)
I would also like to create a quick menu for holes
in the previous cad I had done it and it was very comfortable. .
Also from the assistance they confirm that you can not set the colored threaded holes. .
if set the color are also involved the holes with lamature for example
Did you manage to fix the macro so that it also works with holes created with the work together?
Thanks
Thanks
You mean throwing the macro together? If you mean this should scan all parts and work together?
I mean work together
I'm doing the work on a part together starting from a part that's the merger.
