contrary constraints
  • Thread starter Thread starter DAVID-INVENTOR
DAVID-INVENTOR
Good evening,
I would like by constraint or joint, to make the stems of 2 cylinders move like this: when one climbs the other goes down.
cylinders are not parallel to each other, through any plane.
I thought: to a cylinder I give a hole constraint with the limits or a cylindrical joint, and to the other I do the same, but instead of using numerical limits, I give how variable the movement quotas of the other.. On the contrary.
I'm not wrong, but nothing happens, how come? Thank you.
the bond of cylinder 1 will be called d25 (you can rename it as a race if you want). search for cylinder 2 bond and rename it from dxx to cylinder 1. the movement will be commanded by cylinder 1
Thank you, but that's what I wrote.. :
these cones the bases of the inventor.
I would need to understand why the formulas, so put, do not activate.
hi, I was in 3d modeling for 15 years, Italian is not my native language (Excuse me for my mistakes)
for what you propose, I think you need the stroke of the cylinders, that is the maximum shift of the cylinder, for example l = 180 mm.
one of the cylinders would have commanded the other. we then position a "d1" restriction between the cylinder surface and the cylinder cover that ranges from 0 to 180 mm (l).
in the other cylinder would place the same restriction, only that the formula would be "d2" = l-d1, which would be the same as placing d2 = 180-d1.
something to keep in mind is that this move of both described cylinders is linear. for a more complex scheme, we should design the rest of the parts and limit them correctly.
I hope to be clear and that this can help you, say hello!
allego.. bn evening and thanks cmq for help.
example apart, in reality cylinders do not have common faces among themselves.
What I need is that the movement happens when I move the first cylinder. Thank you.
Hello, excuse me for the delay in the answer.
I come from the old school, that's why I use constraints instead of joins.
I'll show you a video about how I'd do something like that in your video.
the cylinder stroke in the example is 10 mm
I hope it can be useful, and maybe give you an idea to solve your problem.
Bye-bye!
Thank you for filming.
with cinematicism I see the movement of cylinders... My problem is that I needed something like that during the 3d assigned, through the "flexible" command.
I was convinced that, giving a formula, the computer would move "by itself" the stem of the second cylinder, to the change of the first.
I then asked who gives us autodesk products and told me that you can't do it.. "Resolved" problem.
thanks to everyone, next
