DAVID-INVENTOR
Good evening,
I would like by constraint or joint, to make the stems of 2 cylinders move like this: when one climbs the other goes down.
cylinders are not parallel to each other, through any plane.
I thought: to a cylinder I give a hole constraint with the limits or a cylindrical joint, and to the other I do the same, but instead of using numerical limits, I give how variable the movement quotas of the other.. On the contrary.
I'm not wrong, but nothing happens, how come? Thank you.
